PowerShell 1 uruchomienie Win7Pro
#1 Gregis
Gregis
  • 37 postów
Napisano 11 06 2010 - 07:17
po instalacji Win7 uruchamiam PowerShell'a i mam komunikat :
Add-PSSnapin : No snap-ins have been registered for Windows PowerShell version 2.
At C:\Users\Greg\Documents\WindowsPowerShell\profile.ps1:3 char:13
+ Add-PSSnapin <<<< Pscx
+ CategoryInfo : InvalidArgument: (Pscx:String) [Add-PSSnapin], PSArgumentException
+ FullyQualifiedErrorId : AddPSSnapInRead,Microsoft.PowerShell.Commands.AddPSSnapinCommand
The term '\PscxConfig.ps1' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is co
rrect and try again.
At C:\Users\Greg\Documents\WindowsPowerShell\profile.ps1:69 char:2
+ . <<<< "$Pscx:ProfileDir\PscxConfig.ps1"
+ CategoryInfo : ObjectNotFound: (\PscxConfig.ps1:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Windows\system32> Get-ExecutionPolicy
Unrestricted
Pyt1
co jest nie tak ?
Pyt2
jak ustawić aby po kliknieciu na plik.ps1 uruchomił sie jako skrypt ?
