Problem po formacie
#1 eangle
eangle
Napisano 04 04 2011 - 18:43
Witam mam pewien problem z komputerem a mianowicie po właczeniu systemu mam zablokowany pasek zadan ogolnie prawy przycisk myszy nie chodzi moge klikac i nic nie moge wejsc na partycjie itd jedyne co wtedy pomaga to nacisniecie(ctr+alt+del) wywoluje wtedy procesy i wszystko wraca do normy robilem juz 10 razy formaty i nic usuwalem partycjie z płyty windowsa xp i montowalem nowe i tez nic nie pomoglo postaralem sie zrobic logi
Internet Explorer Version: 6.0.2900.5512
Antivirus Program: AVG Anti-Virus Free Edition 2011 10.0 [Enabled - Updated]
--- Checking for Haxdoor ---
checking for a3d files
a3d files not found
checking for matching notify keys
no matching notify keys found
checking for matching services
no matching services found
checking for matching safeboot services
no matching safeboot services found
--- Checking for Goldun - Spybanker ---
checking for SSODL keys
no ssodl keys found
checking for notify keys
no notify keys found
checking for services
no services found
checking for random used files and services
-- these files are not necessarily malicious
-- scanning all folders
C:\Documents and Settings\Pawel\Ustawienia lokalne\Temporary Internet Files\Content.IE5\R5IV4317\creation_6720[1].gif
C:\Documents and Settings\Pawel\Ustawienia lokalne\Temporary Internet Files\Content.IE5\UUBG5WFQ\header-03[1].jpg
C:\WINDOWS\Fonts\ega40857.fon
C:\WINDOWS\Fonts\modern.fon
C:\WINDOWS\inf\adm_mult.PNF
C:\WINDOWS\inf\netdf650.PNF
C:\WINDOWS\SoftwareDistribution\Download\ed56d17c44dff9d33aaccb90b537a1e3\sp3gdr\tsbyuv.dll
C:\WINDOWS\SoftwareDistribution\Download\ed56d17c44dff9d33aaccb90b537a1e3\sp3qfe\tsbyuv.dll
C:\WINDOWS\system32\dllcache\infoctrs.dll
C:\WINDOWS\system32\dllcache\modern.fon
C:\WINDOWS\system32\dllcache\snmptrap.exe
no matching random used services found
checking for browser helper objects
no known browser helper objects found
checking for appinit files
no files found
checking for possible infected files
please submit these file here: http://www.bleepingc....php?channel=11
no files found
checking for Active Setup Installed Components
no known Active Setup Installed Components found
checking iexplore.exe
iexplore.exe is not infected
--- Checking for other Goldun, Spybanker and Haxdoor files ---
no other Haxdoor or Goldun files found
--- Catchme logfile - thank you Gmer ---
catchme 0.3.1398.3 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2011-04-04 19:30:10
Windows 5.1.2600 Dodatek Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden services & system hive ...
scanning hidden registry entries ...
scanning hidden files ...
C:\Documents and Settings\Pawel\Ustawienia lokalne\Temporary Internet Files\Content.IE5\W67FYVJG\widget[1].js 10638 bytes
C:\Documents and Settings\Pawel\Ustawienia lokalne\Temporary Internet Files\Content.IE5\WCW7XUF3\vl.system3[2].gif 807 bytes
scan completed successfully
hidden processes: 0
hidden services: 0
hidden files: 2
--- Analysing Catchme logfile ---
i tu jest kolejny z mbr.exe
tealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.2 by Gmer, http://www.gmer.net
Windows 5.1.2600 Disk: ST3160815AS rev.3.AAD -> Harddisk0\DR0 -> \Device\Ide\IdeDeviceP3T0L0-11
device: opened successfully
user: MBR read successfully
kernel: MBR read successfully
user & kernel MBR OK
tylko nic z nich nie rozumiem a nie moge pozbyc sie tego blokujacego przycisku myszy po starcie systemu
  • 5780 postów
Napisano 04 04 2011 - 19:01
Więc po co zakładasz temat w dziale "wirusowym", skoro sam wiesz, że to nie problem wirusowy?
#3 eangle
eangle
Napisano 04 04 2011 - 19:03
poniewaz nie wiem czy mam wirusa czy nie czy zaszyl sie gdzies w pamieci rozruchowej dysku czy nie cos jest spowodowane reakcjia ze po starcie systemu puki nie nacisne kkombinacji)ctr+alt+del) nie chodzi mi nic nie moge kozystac z paska zadan wejsc na partycjie ogolnie prawy przycisk jest marttwy moze wystarczy gdzies jakas komende odblokowac w regedit ale niestety nei znam sie
  • 5780 postów
Napisano 04 04 2011 - 19:08
Wirus po 10 formatach dysku? Chyba żartujesz?
.Wypróbuj inną myszkę.
W każdym bądź razie to nie jest problem "wirusowy".
#5 eangle
eangle
Napisano 04 04 2011 - 19:24
z tego co wiem ale nei znam sie dlatego oczekiwalem pomocy sa wirusy na ktore format nie pomaga i mozesz formatowac sobie do bolu a i tak problem zostanie. i drugie moze i wirus zostal zwalczony ale niekiedy potrzeba odblokowac jakas komende bo ona poprostu zostaje zablokowana ktos tam kiedys pisal ze usunol wirusa i musial udac sie przez regedit do paska nazedzi i tam zmienic z 0 na 1 albo na odwrot ale to inny problem
#6 perlit
perlit
  • 749 postów
Napisano 05 04 2011 - 00:26
Cześć.
Zapoznaj się z tym link.
