strony internetowe nie wczytują się
#1 Arekrudy101
Arekrudy101
Napisano 27 12 2011 - 16:29
Mam problem tego rodzaju że zainstalowałem ubuntu 10.10 i 90% stron internetowych się nie wczytuje tu załanczam dnsy jakie mam:
szyman@szyman-System-Product-Name:~$ ping -c 10 ubuntu.pl
PING ubuntu.pl (188.165.232.212) 56(84) bytes of data.
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=1 ttl=56 time=65.5 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=2 ttl=56 time=57.0 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=3 ttl=56 time=72.1 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=4 ttl=56 time=48.6 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=5 ttl=56 time=47.6 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=6 ttl=56 time=54.2 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=7 ttl=56 time=55.7 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=8 ttl=56 time=54.2 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=9 ttl=56 time=55.6 ms
64 bytes from ubuntu.ubuntu.pl (188.165.232.212): icmp_req=10 ttl=56 time=60.4 ms
--- ubuntu.pl ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9012ms
rtt min/avg/max/mdev = 47.697/57.139/72.138/6.989 ms
szyman@szyman-System-Product-Name:~$ ping -c 10 188.165.232.212
PING 188.165.232.212 (188.165.232.212) 56(84) bytes of data.
64 bytes from 188.165.232.212: icmp_req=1 ttl=56 time=49.2 ms
64 bytes from 188.165.232.212: icmp_req=2 ttl=56 time=53.8 ms
64 bytes from 188.165.232.212: icmp_req=3 ttl=56 time=61.7 ms
64 bytes from 188.165.232.212: icmp_req=4 ttl=56 time=53.9 ms
64 bytes from 188.165.232.212: icmp_req=5 ttl=56 time=59.0 ms
64 bytes from 188.165.232.212: icmp_req=6 ttl=56 time=64.5 ms
64 bytes from 188.165.232.212: icmp_req=7 ttl=56 time=51.4 ms
64 bytes from 188.165.232.212: icmp_req=8 ttl=56 time=49.0 ms
64 bytes from 188.165.232.212: icmp_req=9 ttl=56 time=49.4 ms
64 bytes from 188.165.232.212: icmp_req=10 ttl=56 time=55.7 ms
--- 188.165.232.212 ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9014ms
rtt min/avg/max/mdev = 49.086/54.818/64.571/5.167 ms
szyman@szyman-System-Product-Name:~$ cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 192.168.1.254
#2 y00r
y00r
Napisano 10 05 2012 - 09:49
Jaki jest komunikat w przeglądarce?
Wyczyśc cache, spróbój inną przeglądarkę, wpisz w adresie przeglądarki adres IP zamiast nazwę strony.
Korzystasz chyba z jakiegoś sprzętowego routera zobacz jego ustawienia i restrykcje dostępu do stron, przeładuj go ewentualnie ustaw do domyślnych i skonfiguruj od nowa albo podłącz kabel internetowy bezpośrednio do komputera jeśli masz poprawny mac adres i zobacz wtedy.
#3 XanTyp
Napisano 10 05 2012 - 20:24
Spojrzałeś na datę postu? Wierzysz, że bez mała od pół roku człowiek czeka jeszcze na odpowiedź?
