* * * * * 2 głosy
SYSTEM REQUIREMENTS
159 odpowiedzi w tym temacie
#31 watermark
watermark
  • 3611 postów
Napisano 01 07 2006 - 23:04
Pro Evolution Soccer 5
SecuROM: v5.03.13.0010
SecuROM: v7
MINIMUM SYSTEM REQUIREMENTS:
Windows 98SE/ME/2000/XP
Intel Pentium III 800MGHz or equivalent processor (Athlon/Duron/Celeron)
128 MB RAM
4X DVD-ROM Drive
NVIDIA GeForce 3 or ATI Radeon 8500 video card
DirectX 8.1 compatible sound card
DirectX 8.1 or higher (included on Disc 1)
Network(TCP/IP 128kbps or higher)
800MB free hard disk space
RECOMMENDED SYSTEM REQUIREMENTS:
Windows 2000/XP
Intel Pentium IV 1.4GHz processor
256 MB RAM
8X DVD-ROM Drive
NVIDIA GeForce 4 Ti, ATI Radeon 9600, or higher
Network(TCP/IP 1.5Mbps or higher)
3GB free hard disk space
SUPPORTED CHIPSETS:
NVIDIA - GeForce FX (5950, 5900, 5800, 5600, 5200), GeForce4 Ti, GeForce3
ATI - Radeon x800, 9800, 9700, 9600, 9500, 9200, 9000, 8500
>d&w<
- Miłego dnia - @watermark™
#32 watermark
watermark
  • 3611 postów
Napisano 02 07 2006 - 09:51
Medal of Honor Pacific Assault
Version 1.0
SafeDisc v2
Recommended Configuration
= Windows XP or Windows 2000
= 2.0+ GHz Intel Pentium IV or AMD Athlon processor
= 512 MB RAM
= 3D video card with 128+ MB video memory which fully supports
DirectX 9.0
= At least 3.0 GB free space on your hard drive for Standard
Edition, and 4.5 GB free space for Director's Edition.
Minimum Configuration
= 1.5 Ghz Intel Pentium IV or AMD Athlon processor
= 512 MB RAM
= 3D video card with 64+ MB video memory which fully supports
DirectX 8.1
Medal of Honor Pacific Assault has been tested with the following
3D video cards under Windows 2000 and Windows XP:
ATI Radeon 8500, 9000 Pro, 9200, 9500, 9600, 9700, 9800
ATI Radeon x300, x600, x800
Nvidia GeForce 3, GeForce3 Ti 200
Nvidia GeForce4 Ti 4200 with AGP8X, GeForce Ti 4600, GeForce4 Ti 4800 SE
Nvidia GeForceFX 5200, 5300, 5500, 5600, 5700, 5750, 5800, 5900, and 5950
Nvidia GeForce 6800
While other cards that fully support DirectX 8.1 may work well,
they have not been tested.
Multiplayer - Dedicated Server Information
TCP AND UDP PORT INFORMATION
Here is a list of all the ports Medal of Honor Pacific Assault™
uses, both TCP and UDP:
80 TCP
6667 TCP
18020 TCP
28910 TCP
29900 TCP
29901 TCP
29920 TCP
13203 UDP
13300 UDP
27900 UDP
29910 UDP
= Only the TCP/IP protocol is supported. IPX does not apply.
= When playing on a LAN, the server only uses UDP port 13203.
= When playing on the internet, the server uses UDP ports 13203,
13300, 27900, 29910 and TCP ports 80, 6667, 18020, 28910,
29900, 29901 & 29920.
= The default port is UPD 13203. If UPD 13203 is already in use
then the game will scan through UDP ports 13204-13218 until it
finds an unclaimed port to use. In situations where multiple
dedicated servers are launched on a single machine, the game
selects the port automatically - it is not necessary to
manually assign the port.
HARDWARE ROUTERS AND FIREWALL DIFFICULTIES
Firewalls and Routers can prevent you from connecting online.
Software Firewalls should be turned off completely to avoid any
issues while playing the game.
Hardware Routers and Firewalls should enable ports as well as
disable the Default Firewall if you’re running Windows XP.
You need to enable port 13203 on your router, and DMZ hosting.
This should allow you to view games online. Other TCP and UDP
ports listed above should also be enabled to prevent complication.
For Router help, please contact your router retailer. To disable
the XP firewall, follow these steps:
1) Double click "My Network Places"
2) Click "View Network Connections"
3) Right click on "Local Area Connection and Select "Properties"
4) Click the "Advanced" tab
5) Make sure to uncheck the box under "Internet Connection
Firewall"
>d&w<
#33 watermark
watermark
  • 3611 postów
Napisano 02 07 2006 - 10:14
Medal of Honor Allied Assault Spearhead Pierwszy "Expansion Pack"
Version 1.0
SafeDisc v2.8
MINIMUM CONFIGURATION
Windows XP, Windows Me, Windows 2000, Windows 98, or Windows 95
(Windows NT is not supported)
Previous installation of Medal of Honor Allied Assault™
450 MHz Intel Pentium II or 500 MHz AMD Athlon processor
128 MB RAM
8x CD-ROM/DVD-ROM drive
800 MB free hard disk space plus space for saved games (additional
space required for Windows swap-file and DirectX 8.0 installation)
16 MB OpenGL capable video card using an NVIDIA GeForce3, NVIDIA
GeForce2, NVIDIA GeForce 256, NVIDIA Riva TNT2, NVIDIA Riva TNT,
ATI Radeon, ATI Rage 128 Pro, ATI Rage 128, PowerVR3 Kyro II, or
PowerVR Kyro chipset with OpenGL and DirectX 8.0 compatible driver
DirectX 8.0 compatible sound card
Keyboard
Mouse
RECOMMENDED
700 MHz or faster Intel Pentium III or AMD Athlon processor
32 MB or greater supported OpenGL capable video card with OpenGL
The following 16MB or greater 3D accelerators are not fully
supported and do not work properly with the game:
-3Dfx Voodoo 4 and 5
No intro movies play. Various textures are corrupted.
Breakable windows are opaque until broken. Once
broken they have a corrupted texture.
-3Dfx Voodoo 3
Various textures are corrupted. Breakable windows are
opaque until broken. Once broken they have a corrupted
texture. Transparent red bomb placements are invisible.
-3Dfx Voodoo Banshee cards
-Matrox G400 and G450
Frame rate is often below 10 frames per second even at
the lowest video settings. Level load times are longer
than normal.
-Nvidia Vanta
These older cards yield a frame rate that is often
below 10 frames per second even at the lowest video
settings.
-PowerVR NEON 250 cards:
Video Logic PowerVR Neon 250
-S3 Savage 2000 cards:
Diamond Viper II
-S3 Savage 4 cards:
Diamond Stealth III S540
Diamond Stealth III S540 Extreme
-SiS 300 cards
The following sound card isn't supported:
-Ensoniq SoundScape PNP
The following sound cards have known problems:
-Diamond Monster Sound MX 400
Requires turning off "DirectSound Acceleration" in the
driver. See the detailed explanation under
"Troubleshooting."
-Creative Labs Audigy
Currently hardware acceleration for this card does not
work correctly.
>d&w<
#34 watermark
watermark
  • 3611 postów
Napisano 02 07 2006 - 12:07
Medal of Honor Allied Assault Breakthrough Drugi "Expansion Pack"
Version 1.0
SafeDisc v2.9
733 MHz Intel Pentium III or 700 MHz AMD Athlon processor
128 MB RAM
800 MB free hard disk space plus space for saved games (additional space required for Windows swap-file and DirectX 8.0 installation)
16 MB OpenGL capable video card using an NVIDIA GeForce, ATI Radeon, NVIDIA Riva TNT2, ATI Rage 128 or PowerVR3 Kyro II chipset
with OpenGL and DirectX 8.0 compatible driver.
GeForce FX Driver Version 4523
-Fog does not appear correctly with driver version 4523.
Installing a newer or older driver will fix this problem.
Keyboard
Mouse
RECOMMENDED
1 GHz or faster Intel Pentium III or AMD Athlon processor
32 MB or greater supported OpenGL capable video card with OpenGL and DirectX 8.0 compatible driver
-3Dfx Voodoo 3
than normal.
-Nvidia Vanta
settings.
Diamond Viper II
-S3 Savage 4 cards:
-SiS 300 cards
"Troubleshooting."
work correctly.
>d&w<
#35 watermark
watermark
  • 3611 postów
Napisano 04 07 2006 - 09:11
18 Wheel of Steel - Across America
Windows 98/ME/2000/XP
Pentium III 700MHz or 100% compatible processor
256 MB RAM
16MB 3D Video Accelerator with DirectX 8.1 compliant video drivers
400MB Hard disk space
4X CD-ROM Drive
Mouse
>d&w<
#36 watermark
watermark
  • 3611 postów
Napisano 05 07 2006 - 01:40
The Sims 2
Wersja 1.0
SafeDisc v3.20.022 lub 024
WYMAGANIA SYSTEMOWE
* Procesor 800 MHz.
* 256 MB RAM-u.
* System operacyjny Windows® XP, Windows ME, Windows 98 lub Windows 2000.
* Co najmniej 3,5 GB miejsca na twardym dysku.
* Karta graficzna obsługująca T&L z co najmniej 32 MB pamięci wideo.
Obsługiwane karty graficzne:
Seria ATI Radeon™ series (7000 i lepsze)
7000, 7200, 7500 (patrz uwaga poniżej)
8500, All-In-Wonder 8500
9000, 9200, 9500, 9600, 9700, 9800
X800
Seria NVIDIA® Quadro™
Quadro, Quadro2, Quadro4
Seria NVIDIA GeForce series (GeForce2 i lepsze)
GeForce 2
GeForce 3, 3 Ti
GeForce 4, 4 Ti, MX 420,440
GeForce FX 5200, 5600, 5700, 5800, 5900, 5950
GeForce 6800
Intel® EXtreme Graphics (patrz uwaga poniżej)
82845, 82865
UWAGA: Jeśli masz kartę nieobsługującą funkcji T&L, taką jak Intel Extreme Graphics lub Radeon 7xxx, będziesz potrzebować procesora co najmniej 2,0GHz.
NIEOBSŁUGIWANE KARTY GRAFICZNE
Jeśli masz kartę graficzną nieobsługiwaną przez grę, The Sims 2 uruchomi się w trybie renderowania programowego. Ten tryb pracy charakteryzuje się wolniejszym działaniem gry i obniżoną jakością grafiki.
Do nieobsługiwanych kart graficznych należą:
ATI Rage Fury
Matrox Millennium G400
Matrox Millennium G550
NVIDIA Riva TNT2
Matrox Parhelia
ST Micro KYRO
S3 DeltaChrome S8
SiS 315
Trident Blade XP
SiS Xabre 400
XGI Volari
>d&w<
#37 watermark
watermark
  • 3611 postów
Napisano 05 07 2006 - 01:55
The Sims 2 University Pierwszy Expansion Pack
Version 1.0
SafeDisc v4.00.001 ale bywają inne wersje SD
WYMAGANIA SYSTEMOWE
* Procesor 800 MHz.
* 256 MB RAM-u.
* At least 1 GB of additional hard drive space (4.5 GB total is required if installing both The Sims 2 and The Sims 2 University at the same time.)
X800
GeForce 2
GeForce 3, 3 Ti
GeForce 6800
82845, 82865
ATI Rage Fury
NVIDIA Riva TNT2
Matrox Parhelia
ST Micro KYRO
S3 DeltaChrome S8
SiS 315
Trident Blade XP
SiS Xabre 400
XGI Volari
>d&w<
#38 watermark
watermark
  • 3611 postów
Napisano 19 07 2006 - 15:24
Hard Truck: Apocalypse
Version 1.03
StarForce v4.0.09.00
SYSTEM REQUIREMENTS
MINIMUM
Windows® 98/ME/2000/XP
DirectX 9.0c (included on disc)
2 GHz Pentium IV or equivalent AMD Athlon XP processor
512 MB RAM
1.0 GB free hard drive space
4x CD-ROM
128 MB DirectX® 9.0c compatible AGP video card
Keyboard, Mouse
RECOMMENDED
3 GHz Intel Pentium IV or equivalent
1 GB RAM
ATI Radeon 9600 pro or equivalent with 128 MB of Video RAM.
>d&w<
#39 watermark
watermark
  • 3611 postów
Napisano 20 07 2006 - 19:01
OutRun2006: Coast 2 Coast
SecuROM v7
Minimum System Requirements
• Microsoft® Windows® 2000/XP
• Pentium® 4 1.3GHz (1300MHz) or equivalent Athlon
• 256MB RAM
• DVD drive
• 1 GB of uncompressed free hard disk space (plus 500MB for Windows® swap file)
• 100% DirectX® 9.0c compatible 16-bit sound card and latest drivers
• 100% Windows® 2000/XP compatible keyboard and latest drivers
• 100% Windows® 2000/XP compatible mouse and latest drivers
• DirectX® 9.0c (included)
• 640 X 480 Monitor Resolution
• 3D Hardware Accelerator Card Required - 100% DirectX® 9.0c compatible 128MB Hardware Accelerated video card and the latest drivers.
Multiplayer Requirements:
• Internet (TCP/IP) and LAN (TCP/IP) play supported.
• Internet play requires broadband connection and latest drivers.
• LAN play requires network interface card and latest drivers.
>d&w<
#40 watermark
watermark
  • 3611 postów
Napisano 24 07 2006 - 10:50
Rush for Berlin
StarForce v3.7.16.04
Minimum Specification
- Windows 2000/XP
- DirectX 9.0b
- Pentium IV or Athlon at 1.5GHz
- 512mb RAM
- Supported 64Mb Graphics card
- DirectX 9 Compatible Sound Card
Recommended Specification:
- Windows XP/2000
- DirectX 9.0b
- Pentium 4 at 2.5 GHz or AthlonXP 2500+
- 1Gb RAM
- Graphics card: GeForce FX 56xx+ or Radeon 97xx+
>d&w<
#41 watermark
watermark
  • 3611 postów
Napisano 29 07 2006 - 18:41
Tiger Woods PGA Tour 2006
SafeDisc v4.5
OS: Windows XP/2000
Pentium III or AMD Athlon XP processor
RAM: 128 MB
CD-Rom/DVD-Rom Speed: 8x
Hard Drive Space: 2.0 GB free hard disc space plus space for saved games, Windows swap-file,
and DirectX 9.0c
Video: 32 MB supported Direct3D capable video card :
Supported 3D Hardware Accelerated video cards include:
a. Windows XP Compatibility
- ATI All-In-Wonder Radeon 8500
- ATI All-In-Wonder Radeon 9600
- ATI All-In-Wonder Radeon 9700
- ATI All-In-Wonder Radeon 9800
- ATI Mobility M6 (Laptop)
- ATI Mobility Radeon 7500 (Laptop)
- ATI Mobility Radeon 9600 (Laptop)
- ATI Radeon
- ATI Radeon 7200
- ATI Radeon 7500
- ATI Radeon 8500
- ATI Radeon 9000
- ATI Radeon 9100 IGP
- ATI Radeon 9200
- ATI Radeon 9250
- ATI Radeon 9500
- ATI Radeon 9550
- ATI Radeon 9600
- ATI Radeon 9700
- ATI Radeon 9800
- ATI Radeon VE
- ATI Radeon X300
- ATI Radeon X600
- ATI Radeon X700
- ATI Radeon X800
- ATI Radeon X850
- ATI Rage 128 All-in-Wonder* **
- ATI Rage Fury* **
- ATI Rage Fury Pro* **
- Intel® Extreme Graphics 82845G/GL
- Intel® Extreme Graphics 82865/G
- Intel® Graphics Media Accelerator 900** ***
- Intel® Graphics Media Accelerator 950** ***
- NVIDIA GeForce 256
- NVIDIA GeForce 6200
- NVIDIA GeForce 6600
- NVIDIA GeForce 6800
- NVIDIA GeForce DDR
- NVIDIA GeForce FX 5200
- NVIDIA GeForce FX 5500
- NVIDIA GeForce FX 5600
- NVIDIA GeForce FX 5700
- NVIDIA GeForce FX 5800
- NVIDIA GeForce FX 5900
- NVIDIA GeForce FX 5950
- NVIDIA GeForce PCX 5300
- NVIDIA GeForce PCX 5900
- NVIDIA GeForce2 GTS****
- NVIDIA GeForce2 MX (AGP)****
- NVIDIA GeForce2 MX 200****
- NVIDIA GeForce2 MX 400****
- NVIDIA GeForce2 Pro****
- NVIDIA GeForce2 Ultra****
- NVIDIA GeForce3*****
- NVIDIA GeForce3 Ti200*****
- NVIDIA GeForce4 MX 420****
- NVIDIA GeForce4 MX 440****
- NVIDIA GeForce4 MX 440 with AGP8X****
- NVIDIA GeForce4 MX 440SE with AGP8X****
- NVIDIA GeForce4 MX 460****
- NVIDIA GeForce4 Ti4200 with AGP8X
- NVIDIA GeForce4 Ti4600
- NVIDIA GeForce4 Ti4800 SE
- NVIDIA nForce 420
- NVIDIA nForce2
- NVIDIA Quadro DDR****
- NVIDIA Quadro SDR****
- NVIDIA Quadro2 MXR****
- S3 Unichrome (MSI)
- S3 Unichrome
- ST Micro KYRO
- Trident Blade XP/T64
- XGI Volari V5 Ultra
- XGI Volari V8
* EA SPORTS™ does not recommend running the game with Dynamic Cameras with these video
cards. For optimal performance, we recommend Fixed View.
** The background of the Main Menu appears to be low detailed.
*** Cameraman towers may exhibit what appears to be z-buffer flickering.
**** When running the game in 16-bit color, there are minor z-buffer fighting/buffer issues that
appear on trees and buildings in the background.
***** When water detail is set to "High" under the graphic detail settings for the game, the
water textures on lakes/ponds become corrupt.
*Note:
- If you have an older NVIDIA TNT2 video card you may be able to run the game by using the following
older drivers: (version 61.77)
- 1600x1200 video screen resolution is only available on video cards with 256 MB of video RAM
- If you have an NVIDIA GeForce 6800 Ultra SLI configurated system and choose the 3-click control
method, you will experience graphical corruption at the bottom of the screen when clicking for hit
strength. Please check for updated drivers from NVIDIA to correct this.
Sound: DirectX 9.0c compatible sound card
Input: Keyboard, Mouse
SUPPORTED VIDEO CHIPSETS: NVIDIA: GeForce SDR/DDR, GeForce 256, GeForce 2/2MX/2MXR/Ultra, GeForce
Quatro, GeForce Quadro/Quadro2/Quadro DDR, GeForce 3/Ti200/Ti500, GeForce 4 MMX/Ti 4200/Ti
4400/Ti 4600, GeForce 2-go, GeForce 4 MX 2-go, Nvidia NV-17, GeForce FX 5200/5600/5900/6800
ATI: Rage 128/Rage Fury/Rage 128 Pro/Rage Pro Ultra/Rage, Pro GL/GL2,
Radeon 7000/7500/8500/9000/9200/9600/9700/9800/X800/VE, ATI All-in-wonder
>d&w<
#42 watermark
watermark
  • 3611 postów
Napisano 12 08 2006 - 08:42
Version 1.0
128 MB RAM
1.2 GB free hard disk space plus space for saved games (additional
Keyboard
Mouse
RECOMMENDED
-3Dfx Voodoo 3
than normal.
-Nvidia Vanta
settings.
Diamond Viper II
-S3 Savage 4 cards:
-SiS 300 cards
"Troubleshooting."
work correctly.
>d&w<
#43 watermark
watermark
  • 3611 postów
Napisano 15 08 2006 - 22:51
Volkswagen GTI Racing
GTI Racing™
StarForce v4.00.013.003 (FrontLine Pro)
I REQUISITI MINIMI DI SISTEMA
Windows 98/ME/2000/XP;
Processore P IV o AMD Athlon a 1.8 GHz;
256 MB di RAM;
Scheda grafica con 64 MB di memoria, compatibile con DX 8.0 (GeForce 3 o ATI Radeon 9200)*;
Scheda sonora compatibile con DX 8.0;
2,5 GB di spazio libero su disco rigido;
DirectX 9.0c;
Lettore DVD–ROM;
Modem 56k (per giocare in modalitŕ multigiocatore su internet).
II REQUISITI DI SISTEMA CONSIGLIATI:
Processore P IV o AMD Athlon a 2.5 GHz;
512 MB di RAM;
Scheda grafica con 128 MB di memoria, compatibile con DX 9.0 (GeForce 5700 o ATI Radeon 9600)*;
DirectX 9.0c;
Lettore DVD–ROM;
Connessione Internet ISDN (per giocare in modalitŕ multigiocatore su internet).
Ricorda che le schede video che non offrono supporto T&L hardware non soddisfano pienamente i requisiti minimi per giocare, e possono provocare problemi di prestazioni. Per funzionare correttamente, il gioco necessita di una scheda video con Pixel Shader 1.1.
* Il gioco non supporta schede video GeForce 4MX.
by @mateusz19900
>d&w<
#44 driven
driven
  • 4287 postów
Napisano 07 11 2006 - 11:19
Need For Speed™ Carbon
WYMAGANIA MINIMALNE
OS: Windows XP Service Pack 2 (32Bit Edition only), Windows 2000 Professional Service Pack 4 operating system
Procesor: Intel Pentium 4 (or equivalent) CPU running at 1.7GHz or higher
Karta graficzna: 64MB DirectX 9.0c compatible video card (NVIDIA Geforce4 Ti/ATI Radeon 8500 or higher) using a supported chipset (see below)
Pamięć RAM: 512MB RAM
Karta dźwiękowa: DirectX compatible sound card
5.3 GB of HD space
8X or faster DVD Drive
NVIDIA GeForce4 Ti-4200
NVIDIA GeForce4 Ti-4400
NVIDIA GeForce4 Ti-4600
NVIDIA GeForce4 Ti-4800
NVIDIA GeForce FX Series
NVIDIA GeForce 6200
NVIDIA GeForce 6600
NVIDIA GeForce 6800
NVIDIA GeForce 7300
NVIDIA GeForce 7600
NVIDIA GeForce 7800
NVIDIA GeForce 7900
ATI Radeon 8500
ATI Radeon 9000
ATI Radeon 9100
ATI Radeon 9200
ATI Radeon 9500
ATI Radeon 9550
ATI Radeon 9600
ATI Radeon 9700
ATI Radeon 9800
ATI Radeon X300
ATI Radeon X550
ATI Radeon X600
ATI Radeon X700
ATI Radeon X800
ATI Radeon X850
ATI Radeon X1300
ATI Radeon X1600
ATI Radeon X1800
ATI Radeon X1900
***NOTE: Laptop versions of these chipsets may work, but are not officially supported. NVIDIA GeForce MX series not supported.
Need for Speed Carbon uses the following TCP and UDP port(s) for
Internet play:
TCP:
TCP 18210
TCP 18215
TCP 13505
UDP:
Outgoing: 18215, 20000 to 22000
Incoming: 3658, 1042
Katalog z zapisanymi stanami gry (savy) znajdują się:
\Documents and Settings\Nazwa urzytkownika\Moje dokumenty\NFS Carbon
#45 watermark
watermark
  • 3611 postów
Napisano 04 03 2007 - 19:44
18 Wheels of Steel: Haulin'
Pentium 4 1.4 Ghz or 100% compatible
256 MB RAM
540 MB HD Space
64 MB DirectX/Direct3D and T&L compatible video accelerator card
DirectX 9.0c or later
Mouse
CD-Rom drive
>d&w<
Użytkownicy przeglądający ten temat: 1
    Bing (1)
