Frog ASPI - Alternatywny sterownik ASPI
Napisano 08 08 2007 - 15:44
Frog ASPI
Platforma: Windows 2000/XP/2003/Vista 32-bit i 64-bit
Ogólne wyjaśnienie ASPI i kwestii montażowych: klik. W artykule są proponowane sterowniki Adaptec. Frog ASPI to niezależny alternatywny sterownik warstwy ASPI. Może być zastępstwem dla sterowników Adaptec / Nero etc. Benefity rozwiązania: sterownik może być wykorzystany do pracy dowolnego programu wypalającego, prawidłowe wsparcie dla urządzeń USB/Firewire. Montaż sterownika: zmienić nazwę pliku FrogAspi.dll na WnAspi32.dll i wymienić znalezione w systemie kopie pliku wnaspi32.dll nowoutworzonym. Kopie są w C:\WINDOWS\system32 oraz w folderach danego programu wypalającego (np. C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll). Więcej w FAQ.
Some softwares as wellknown CD copy tools, have their own driver. What's the difference with FrogAspi?
It's very hard to explain... if you're not a developer...
At the base, all these engines are common. They serve as link between the software, the NT kernel for the SPTI communication, and devices.
Each engine is specific to its own company, and can't be used by others. The engines are accessible only for each dedicated program.
For additional functionality: right administrators, to block certain functions (ex: detection of the type of inserted media: Cd-R or cdrom), this engine is coded as a driver.
this driver is loaded directly with the kernel and influences it... although the driver is supposed to be accessible only to its program.
Driver programming is reserved only to very experienced developers.
Well, imagine you are using the softwares X,Y,Z.... and that the X driver interacts with the Y one... the system is unstable!
For these reasons, I decided to use an easier solution, accessible to all programs: the engine is in a library. Every program can communicate with devices, using the ASPI protocol, with frogASPI.
