eMule ScarAngel Mod
9 odpowiedzi w tym temacie
#1 Da GuRu
Da GuRu
  • 102 postów
Napisano 13 08 2007 - 17:44
eMule 0.48a ScarAngel v2.1
eMule v0.48a ScarAngel v2.1:
- 13.08.2007 -
based on eMule 0.48a Xtreme 6.1 compiled with vs2003 SP1
Added: Do not reserve 1/3 of your uploadlimit for emule [Stulle] - Stulle
Added: Disable accepting only clients who asked within last 30min [Stulle] - Stulle
+ Xtreme only grants upload to clients that asked within the last 30min
Added: Follow The Majority [AndCycle/Stulle] - Stulle
Added: Fair Play [AndCycle/Stulle] - Stulle
Added: Alwasy maximize slot speed [Stulle] - Stulle
Added: Timer for ReAsk File Sources [Stulle/ idea from sivka] - Stulle
+ Due to Spread Reasks the actual ReAsk time is: [SetTime]+{-3...0.5 minutes}
Changed: check mark superior to icon (MenuXP) [fafner] - Stulle
Changed: Quickstart for KAD-only connection [Stulle] - Stulle
Changed: No FunnyNick for bad guys [Stulle] - Stulle
Changed: Max enforced ratio to 1:10 [Stulle] - Stulle
Fixed: Saving of Cat version (save default Cat viewfilters) [Stulle] - Stulle
Fixed: GDI-Leaks around the context menus [Stulle] - Stulle
Do not reserve 1/3 of your uploadlimit for emule:
+ Only active if you upload more than download in this session.
+ Reserves only a minimum of 2 kB/s for eMule.
Download Mirrors:
eMule-0.48a-ScarAngel-v2.1-bin.rar
eMule-0.48a-ScarAngel-v2.1-src.rar
Download more versions of eMule ScarAngel.MoD
Features & Changelogs for eMule ScarAngel.MoD
Rate eMule ScarAngel.MoD @ emule-mods.de !!!
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki
#2 Da GuRu
Da GuRu
  • 102 postów
Napisano 09 09 2007 - 00:36
eMule 0.48a ScarAngel v2.2
eMule v0.48a ScarAngel v2.2:
- 08.09.2007 -
Changed: Recode of the file settings [Stulle]
Fixed: Crashfix in Upload list (FairPlay code) [Stulle] - Stulle
Fixed: Odd word invention "constantinously" to "constantly" [LorenzC]- Stulle
Fixed: Some more mem leaks [fafner] - Stulle
File Settings:
+ all .sivka files will be deleted
+ all settings will be stored in the FileSettings.ini
+ supports all current settings by StulleMule and ScarAngel
+ settings are saved on taking over SivkaFileSettings and on closing eMule
Download Mirrors:
eMule-0.48a-ScarAngel-v2.2-bin.rar
eMule-0.48a-ScarAngel-v2.2-src.rar
#3 Da GuRu
Da GuRu
  • 102 postów
Napisano 17 09 2007 - 15:54
eMule 0.48a ScarAngel v2.3
eMule v0.48a ScarAngel v2.3:
- 17.09.2007 -
Added: Advanced Options [Official/leuk_he] - Stulle
Added: handling of one-time-events for Scheduler [Mighty Knife] - Stulle
Added: Weekly IPFilter update [leuk_he] - Stulle
Added: IP2Country update [MorphXT] - Stulle
Added: One click update for antiLeech.dll [Stulle] - Stulle
Added: Auto update antiLeech.dll [Stulle] - Stulle
Added: Display data difference on PBF in UploadList [Stulle] - Stulle
Changed: ASFU: Moved EndCall [Stulle] - Stulle
Changed: AFSU: Reset when en-/disabled [Stulle] - Stulle
Changed: Update IPFilter on every startup if enabled [Stulle] - Stulle
Changed: antiLeech.dll, ip-to-country.csv & ipfilter.dat not in BIN pack [Stulle] - Stulle
+ files will be updated/ downloaded on startup by default
Changed: Auto update IPFilter migrated to Update tab [Stulle] - Stulle
Changed: Enforce Ratio will start when configured ratio-0.1 reached [Stulle] - Stulle
+ Examples: 1:1 -> 1:0.9 ; 1:3 -> 1:2.9 ; 1:5 -> 1:4.9 ; ...
Changed: Enforce 1:1 ratio when configured enforce ratio exceeded [Stulle] - Stulle
Changed: Increased max slotspeed by 25% [Stulle] - Stulle
+ WARNING: If upload is less stable decrease slotspeed and/or enable OpenMoreSlots!
Changed: Increased maximum possible slot speed to 19 (by 26.6666%) {Stulle] - Stulle
Changed: Decrease MinSlots value and minmum by one if UL-health >= 75% [Stulle] - Stulle
Changed: Decrease MaxSlots value by one if slotspeed > 4kbps [Stulle] - Stulle
Changed: MuleListCtrl context menu (column context) in XP Style [Stulle] - Stulle
Changed: Icon for share folder commands in context menu [Official] - Stulle
Fixed: Loading of Cat version (fix default cat settings) [Stulle] - Stulle
Download Mirrors:
eMule-0.48a-ScarAngel-v2.3-bin.rar
eMule-0.48a-ScarAngel-v2.3-src.rar
#4 Da GuRu
Da GuRu
  • 102 postów
Napisano 14 10 2007 - 20:21
eMule 0.48a ScarAngel v2.4
eMule v0.48a ScarAngel v2.4:
- 14.10.2007 -
Changed: Override max upload session time for PBF clients [Stulle] - Stulle
Changed: Override max upload session time for friends [Stulle] - Stulle
Changed: Keep friends in upload like PBF clients [Stulle] - Stulle
Changed: Do not reserve 1/3 if ratio is max 1:2 [Stulle] - Stulle
Changed: Only give back waitingtime if transferred < 9MB [Stulle] - Stulle
Changed: Do not give back waitingtime if it would be more than the old [Stulle] - Stulle
Changed: Only give back waitingtime if transfer completed [Stulle] - Stulle
Changed: Only give back waitingtime if SUQWT or FullChunk enabled [Stulle] - Stulle
Changed: Friends with friend slot always get superior status [Stulle] - Stulle
Fixed: Possible buffer overun in Enforce Ratio code [Stulle] - Stulle
Fixed: Do not reserve 1/3 of your uploadlimit for emule [Stulle] - Stulle
Fixed: Missed to enable Auto IPfilter update by default [Stulle] - Stulle
Download Mirrors:
eMule-0.48a-ScarAngel-v2.4-bin.rar
eMule-0.48a-ScarAngel-v2.4-src.rar
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki - Nodes.dat
#5 Da GuRu
Da GuRu
  • 102 postów
Napisano 28 12 2007 - 02:09
eMule 0.48a ScarAngel v2.5
eMule v0.48a ScarAngel v2.5:
- 28.12.2007 -
Added: Links for Server list and nodes file [Stulle] - Stulle
Added: High resolution speedmeter on toolbar [eFMod/Stulle] - Myth88
Changed: Do not restrict download if no upload possible [Stulle] - Stulle
Fixed: Resume mode combobox in Categorie dialog [Stulle] - Stulle
Fixed: Auto Update IP2Country on startup [Stulle] - Stulle
Fixed: Do not reserve 1/3 of your uploadlimit (finally!) [Stulle] - Stulle
Fixed: URL input for updates [Stulle] - Stulle
Fixed: Design Settings (backgrounds and windows were broken) [Stulle] - Stulle
eMule ScarAngel.MoD Homepage
Download Mirrors:
eMule-0.48a-ScarAngel-v2.5-bin.rar
eMule-0.48a-ScarAngel-v2.5-src.rar
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki - Nodes.dat (eMule KAD)
#6 Da GuRu
Da GuRu
  • 102 postów
Napisano 06 07 2008 - 01:08
eMule 0.49a ScarAngel v3.0
eMule v0.49a ScarAngel v3.0:
- 06.07.2008 -
Merged to eMule v0.49a [Stulle]
- Xtreme's heir -
Added: Auto download priority [tommy_gun/iONiX] - MyTh
Added: MenuXP Sub Heading [fafner] - MyTh
Changed: Context menu Sidebars show mod version [Stulle] - MyTh
Changed: Context menu title shown as sub heading [Stulle] - MyTh
Changed: Localize Source Graph group box [Stulle/thx pennyliu123] - Stulle
Changed: Localize Push Small Files label above slider [Stulle/thx pennyliu123] - Stulle
Changed: Localize TBH: MM group item [Stulle/thx pennyliu123] - Stulle
Changed: Localize "12h" string for Release Bonus [Stulle/thx pennyliu123] - Stulle
Changed: Updated UPnP implementation, UPnP lib and PThread lib [leuk_he] - Stulle
Changed: Updated IP2Country implementation [MorphXT] - Stulle
Changed: Updated libping to 1.28 (which is same source as 1.27) [leuk_he] - Stulle
Changed: Updated CxImage to 6.00 (we use the rather complete lib) [Stulle] - Stulle
Changed: No increased reask time for Mephisto clients [Stulle] - Stulle
Changed: No Pay back First for non-SUI clients if client ident failed [Stulle] - Stulle
Changed: Only draw credits overlay icon for mods [Stulle] - Stulle
Changed: Creation of TBH: MiniMule (won't show up on startup now) [Stulle] - Stulle
Changed: Display warning in Design Panel for all Windows > XP [Stulle] - Stulle
Changed: Made Compat clients stats code prettier [WiZaRd] - Stulle
Changed: Ban clients with reduced score immediatly on setting changed [Stulle] - Stulle
Changed: Keep Sup clients in up if there is no other sup client in queue [Stulle] - Stulle
Fixed: Do not restrict download if no upload possible [Stulle] - Stulle
+ missed merging the proper version of this code on releasing
Fixed: Anti-Uploader-Ban case 2 and 3 (horribly old...) [Stulle] - Stulle
Removed: Redundant File Settings code (old) [Stulle] - Stulle
Removed: Safe KAD code and thelike (for now) [Stulle] - Stulle
Removed: Xtreme version check (not working for now) [Stulle] - Stulle
Download Mirrors:
eMule-0.49a-ScarAngel-v3.0-bin.rar
eMule-0.49a-ScarAngel-v3.0-src.rar
#7 Da GuRu
Da GuRu
  • 102 postów
Napisano 13 10 2008 - 14:48
eMule 0.49b ScarAngel v3.1
eMule v0.49b ScarAngel v3.1
- 09.10.2008 -
based on eMule 0.49b Xtreme 7.0 compiled with vs2005 SP1
Merged to eMule v0.49b [Stulle]
Added: IP Filter White list [Stulle] - Stulle
Added: TK4 CreditSystem [BlueSonicBoy] - Stulle
Added: ZZUL CreditSystem [ZZ] - Stulle
Added: Modified FineCS [CiccioBastardo/Stulle] - Stulle
Added: Advanced Transfer Window Layout [Stulle] - Stulle
Added: Completed in Tray [Stulle] - Stulle
Added: Threaded File Settings Saving [Stulle] - Stulle
+ keeps the GUI responsive while saving
Added: Threaded Known Files Saving [Stulle] - Stulle
Added: On Upload Queue in Copy Feedback feature [MyTh88] - MyTh88
Added: New IPFilter (Maintained by Ozzy) [Stulle] - Stulle
+ uses DynDNS to check version, mirrored at SourceForge, unrar.dll required!
Added: Show (un-)loading status of IPFilter [Stulle] - Stulle
Added: Sum up transferred stats on getting Feedback for multiple files [Stulle] - Stulle
Added: Color Upload Feedback [MyTh88]- MyTh88
Changed: Improved resizing of cats tab in SearchResultWnd [Stulle] - Stulle
Changed: Using official code for proper background of Icons with text [Officials] - Stulle
Changed: Cleaned up Static IP Filter code [Stulle] - Stulle
+ only ipfilter.dat layout allowed!
Changed: Toolbar icons [Tango/schluepfer] - Stulle
Changed: Waiting Queue icon [Microsoft] - Stulle
Changed: Known Clients icon [Aha-Soft] - Stulle
Changed: Upload and Download icon [Studiomx] - Stulle
Changed: Downloading Files icon [Fast Icon] - Stulle
Changed: Increased font size for Sub Heading text in context menu [Stulle] - Stulle
Changed: Use proper English in some places :D [ginger] - Stulle
Changed: Reworked the Feedback code a bit [Stulle] - Stulle
Changed: Enable List requested files only when needed [Stulle] - Stulle
Changed: Rewrote Feedback code [Stulle] - Stulle
Changed: Only identified and not available SUI clients can be superior [Stulle] - Stulle
Changed: Make code VS 2005 and VS 2008 ready [MorphXT] - Stulle
Changed: Some more changes for Advanced Options [MorphXT] - Stulle
Fixed: InputBox for ResumeOrder [Stulle/fafner] - Stulle
Fixed: Crash when checking if sup client should not be kicked from UL [Stulle] - Stulle
Fixed: Improper use of FindBestClientInQueue when checking for sup client [Stulle] - Stulle
Fixed: No max time for clients that should be prevented [Stulle] - Stulle
Fixed: Not working chars for context menus [Stulle] - Stulle
Fixed: Scheduled DLP Update not working [Stulle] - Stulle
Fixed: Memleak FiX in SysInfo [WiZaRd] - Stulle
Fixed: Corrupted BarShaderInfo [fafner] - Stulle
Fixed: Corrupted SpreadBarInfo [fafner] - Stulle
Removed: Second CryptTCPPaddingLength option from Advanced Options [Stulle] - Stulle
Removed: Last renmants of the Xtreme version check [Stulle] - Stulle
Removed: Drop Win95 support (for VS2008 compatibility) [MorphXT] - Stulle
IP Filter White List:
+ IPs on this list will not be banned
+ use ipfilter_white.dat to add IPs to the White List
Advanced Transfer Window Layout:
+ Any two lists can be viewed at the same time
+ Downloading file list can only be viewed in the upper part
+ If list shown in the upper half is already in the lower half the lower
list changes to next list
+ To disable/ enable press the split button/ item
Download Mirrors:
eMule-0.49b-ScarAngel-v3.1-bin.rar
eMule-0.49b-ScarAngel-v3.1-src.rar
#8 Da GuRu
Da GuRu
  • 102 postów
Napisano 17 09 2009 - 22:18
eMule 0.49c ScarAngel v3.2
eMule v0.49c ScarAngel v3.2:
- 17.09.2009 -
based on eMule 0.49c Xtreme 7.2 compiled with vs2005 SP1
Merged to eMule v0.49c [Stulle]
Updated with code from zz_fly's Xtreme
Added: Static Tray Icon [MorphXT] - MyTh88
Added: (Design Settings) Shareable file style for SharedFilesCtrl [Stulle] - Stulle
Added: Feedback personalization [Stulle] - Stulle
Added: Advanced option to disable/enable MediaDet usage for media files [Stulle] - Stulle
Added: Display friendslot in UploadListCtrl (Status colum) [Stulle] - Stulle
Added: More media info related hidden options [Stulle] - Stulle
Changed: Updated ASFU to v3.4 to work with single shared files [Stulle] - Stulle
Changed: Updated Design Settings for new code (also improves implementation) [Stulle] - Stulle
Changed: Always wait 5 sec after sending save req before saving file settings [Stulle] - Stulle
Changed: Write FileSettings.ini sequentially (faster) [Stulle] - Stulle
Changed: Global SysInfo RAM stats will support usage of more than 4GB [Stulle] - Stulle
Changed: Min small files push size to 1 kB [Stulle] - Stulle
Changed: Small files push size slider kB based (makes keyboard input usable) [Stulle] - Stulle
Changed: (Design Settings) Allow to use multiple font styles (B/U/I) at once [Stulle] - Stulle
Changed: (Design Settings) Changed version to v3 for above change [Stulle] - Stulle
+ import of v2 is done automatically on startup
Changed: Localize ScarAngel string in Preferences panel list [Stulle] - Stulle
Changed: Updated Enhanced Client Recognition to v2 (minor change) [Spike2/WiZaRd] - Stulle
Fixed: Save known or FileSettings threads were not terminated properly [Stulle] - Stulle
Fixed: Some glitches around Timer for ReAsk File Sources [Stulle] - Stulle
Fixed: Changing the small files push size reset changes in the Tree options [Stulle] - Stulle
Fixed: Some glitches around enabling/disabling the Speedbars in the toolbar [Stulle] - Stulle
Fixed: Don't reset Connection Settings for Webserver/CML/MM [Stulle] - Stulle
Removed: Color Upload Feedback [MyTh88]- MyTh88
Feedback personalization:
+ integrated into Design Settings
+ allows you to change font style and color of the feedback
+ Label style will be applied to the whole feedback block
+ Default style will be applied if color is default and no font style is set
Download Mirrors:
eMule-0.49c-ScarAngel-v3.2-bin.rar
eMule-0.49c-ScarAngel-v3.2-src.rar
#9 Da GuRu
Da GuRu
  • 102 postów
Napisano 03 12 2009 - 22:00
eMule 0.49c ScarAngel v3.3
eMule v0.49c ScarAngel v3.3:
- 03.12.2009 -
based on eMule 0.49c Xtreme 7.2 compiled with vs2008 SP1
Added: Date File Name Log (enabled by default) [AndCycle] - Stulle
Added: Ionix advanced (multiuser) webserver [iOniX/Aireoreion/wizard/leuk_he/Stulle] - Stulle
Added: Multiuser WebInterface (WI) Cookie settings [Aireoreion] - Stulle
+ added code missing in MorphXT so it works
Added: New failed login handling for WI [MorphXT/leuk_he/dreamwalker/Stulle] - Stulle
Added: Failed login screen for WebInterface [SiRoB/CommanderGer/Stulle] - Stulle
+ Also for multiuser WI
Added: Tabbed WebInterface settings panel [Stulle] - Stulle
+ For multiuser settings
Added: Extra logging to notify of missing webserver files [leuk_he] - Stulle
Added: PowerShare support for WebInterface [Stulle] - Stulle
+ fixed missing tick in menu and improper table display from StulleMule
Added: Rebind UPnP mappings (UDP, TCP and Webserver for now) like official [Stulle] - Stulle
Added: Run eMule as NT Service [leuk_he/Stulle] - Stulle
+ localized logging, cleaned up code
Added: Adjustable NT Service Strings [Stulle] - Stulle
Added: Extended Prompt on Exit dialog [leuk_he] - Stulle
Added: Friendslot support for WebInterface [Stulle] - Stulle
Added: Installer for eMule ScarAngel [leuk_he/Stulle] - Stulle
+ translations taken from eMule Morph so credits to the respective creators
Changed: Disable FollowTheMajority per file when file is renamed manually [AndCycle] - Stulle
Changed: Disable ASFU if too many folders are shared [Stulle] - Stulle
+ fixes related crashes; increases ASFU version number to 3.5
Changed: Only display cat selection dialog if there is more than one cat [Stulle] - Stulle
Fixed: Sorting priority descending failed for powershared files [Stulle] - Stulle
Fixed: UPnP setting in First Runtime Wizard [leuk_he] - Stulle
Fixed: Port settings in First Runtime Wizard for Random Ports feature [leuk_he] - Stulle
Fixed: Missing checkmark for PS limited by amount context menu [Stulle] - Stulle
Fixed: (Official) Malfunctioning search results in eMule Light template [Stulle] - Stulle
Fixed: Show last tab in ScarAngel prefs panel on reopening prefs dialog [Stulle] - Stulle
Fixed: Show friend menu in Friendlist of Webinterface [Stulle] - Stulle
Fixed: Design settings font colors overridden in UploadListCtrl [Stulle] - Stulle
Fixed: Personalize Feedback could not be turned off [Stulle] - Stulle
Note: Following languages updated/added: German [Stulle]; French [Heaven];
Chinese (P.R.C.) [jason_jiang]; Italian [Idro182]; Turkish [omeringen];
Spanish [guijarrelson]; Chinese (Taiwan) [alisa/DargonD]
Ionix advanced (multiuser) webserver:
+ You must select the multi user template to enable the multi user settings.
+ Changed user privileges (see below)
+ Added option to restrict user from downloading files via webserver.
+ Multiuser is enabled/disabled automatically on changing template.
Ionix advanced (multiuser) webserver user privileges:
+ Guest: Viewing information from webinterface
+ Operator: Adding/Removing downloads and according to other settings
+ Admin: Like Operator plus privilege to close eMule
+ Hi-Admin: Like Admin plus privilege to shutdown/reboot windows
Run as NT Service:
+ No need to login into windows
+ Keeps running after logging out/ switching users
+ New command line options:
- "emule -install" --> install as a service
- "emule -uninstall" --> uninstall as a service
+ Make sure all settings are correct before installing as a service
+ Links are passed to webservice
+ Option to set level of optimization (Full may cause errors!)
+ See Preferences->Web Server->NTservice tab
Download Mirrors:
eMule-0.49c-ScarAngel-v3.3-installer.exe
eMule-0.49c-ScarAngel-v3.3-bin.exe
eMule-0.49c-ScarAngel-v3.3-src.rar
#10 Da GuRu
Da GuRu
  • 102 postów
Napisano 13 03 2011 - 06:24
eMule 0.50a ScarAngel v4.0
eMule v0.50a ScarAngel v4.0
- 11.03.2011 -
based on eMule 0.50a Xtreme 8.0 compiled with vs2010 SP1
Merged to eMule v0.50a [Stulle]
Added: Possibility to directly add incoming of removed cat to shared folders [Stulle] - Stulle
Added: Queue progress bar in Webserver (not in Light) [unknown/Stulle] - Stulle
Added: File Percentage in title of progress images in WebServer [unknown/Stulle] - Stulle
Added: More advanced official settings [Stulle] - Stulle
Changed: Reworked coloring of windows (fixes some tab controls on Vista/7) [Stulle] - Stulle
Changed: Grouping of advanced official settings [Stulle] - Stulle
Changed: Refined dislpaying reasons for download limits in StatusBar [Stulle] - Stulle
Changed: Auto join Morph IRC help channel [Stulle] - Stulle
Changed: Improved picking correct download limit [Stulle] - Stulle
+ Might be a little more restrictive but is is also cleaner
Fixed: Reboot in webserver invoked shutdown instead of reboot [Stulle] - Stulle
Fixed: TxtEditor option in Advanced Preferences [Stulle] - Stulle
Fixed: Setting HOS was cancled when setting remained unchanged for one file [Stulle] - Stulle
Fixed: Minor display bug around default for PowerShare limit [Stulle] - Stulle
Fixed: AutoUpdateIP2Country differed on loading and saving preferences [jerryBG] - Stulle
Fixed: Localization of ScarAngel Settings was incomplete [Stulle] - Stulle
Fixed: Bad graph label display when Source Graph was disabled [Stulle] - Stulle
Fixed: Crashfix for reloading share via ASFU under certain circumstances [WiZaRd] - Stulle
Fixed: Current window was not entirely redrawn on changing window color [Stulle] - Stulle
Fixed: DLP version number was not updated on manual update in settings [Stulle] - Stulle
Removed: New official Ask-On-Exit Dlg in favor of ScarAngel one (NTService) [Stulle] - Stulle
Note: Following languages updated: German [Stulle]; Chinese (P.R.C.) [zz_fly];
Chinese (Taiwan) [AndCycle]; French [jamjam]; Spanish [RaJiL/mself563];
Italian [xilolee/EvolutionCrazy]; Turkish (partially) [omeringen]
Note: Added existing Czech ScarAngel translations to Czech translation file
Download Mirrors:
eMule-0.50a-ScarAngel-v4.0-installer.exe
eMule-0.50a-ScarAngel-v4.0-src.rar
